New introduction of ASSO RC200
assocista
Message par assocista » 06 Août 2010, 12:44
Hello, This is the new introduction about one of RC200 which I have.
As you know, RC200 cares very much in an active vehicle about the selection of parts in the end of 70's.
Especially for the matching of Muff/Carb and plus one more something new for the charm point.
Here attached is a kind of realization for that after long working.
If it will be getting Ref, a little for your restoration, I am fine :D
Details are roughly as below.
*Motor: K&B McCOY modified
*Carb: OPS 8.0mm Inlet slide (the collaboration of K&B and OPS carb was popular at that time)
*Muff: Early article of McCOY Can Muff (Silver)
*Brake Arm: replace to White Nylon one (choice from Thorp production)
*Reinforcement of the servo
*Visible Air Filter
*Webra Fuel Filter
Enjoy :wink:
↓around power unit
ASSOCISTA :)
Message par simonsg » 06 Août 2010, 20:42
Very very nice luv these radio plate funky cuts, and all the other small nice bits :ok: Great works :bravo:
assocista
Message par assocista » 07 Août 2010, 00:38
Bonjour Simonsg, Many thanks always for your compliment :D
How is your RC300?
I can not wait to see your miracle working for it :lol: :D
ASSOCISTA :fete:
OCA1
Message par OCA1 » 07 Août 2010, 05:20
Bravo:!: Very beautiful rc200, I like all the rare details you put in to this car :ok: It will be an inspiration for my own rc200 restoration in the near future.
OCA1 :)
assocista
Message par assocista » 07 Août 2010, 05:49
Hi OCA1
I am quite happy that it will be good ref, for your next restoration :D
Here is one more shot. Pls enjoy :fete:
ASSOCISTA :)
assocista
Message par assocista » 08 Août 2010, 06:50
Currently I fond that the front rim of MRP is very good matching to RC200.
The design has a similar holes as the RC200 original one.
Below is set up with that.Enjoy :)
ASSOCISTA :fete:
OCA1
Message par OCA1 » 08 Août 2010, 17:44
ASSOCISTA, the MRP wheel llooks good on your RC200, it has a similar design, but it looks that it has a larger diameter. :ok: Did you use a special adaptor to fit it, or does it have the same bearing/bushing size as the original RC200 wheel?
Cheers,
OCA1 :)
assocista
Message par assocista » 09 Août 2010, 00:30
OCA1, The diameter of MRP is larger exactly compared with RC200's.
It's the same diameter as the front rim of RC300.
As I make the shape of tire lower profile looking like 35/40, It looks larger :lol:
The special adapter is not necessary to use. Because the axle shaft is the same one and just insert it except the s/steel collar 8)
MRP had the other version,which was ball bearing spec as well.
ASSOCISTA :)
OCA1
Message par OCA1 » 09 Août 2010, 06:36
ASSOCISTA, The MRP wheel is pretty cool looking, it looks like a larger diameter wheel and with low profile tires it looks super! 8) Thank you for the nice rim comparison picture.
This is a ball bearing version of the RC300 wheel :ok:
OCA1 :)
assocista
Message par assocista » 09 Août 2010, 07:48
OCA1 a écrit :ASSOCISTA, The MRP wheel is pretty cool looking, it looks like a larger diameter wheel and with low profile tires it looks super! 8) Thank you for the nice rim comparison picture.
OCA1 :)
Oh yes,This is more competition item ! Large bearing is a great durability :ok: :ok:
ASSOCISTA :)
