récupération de pneus mousse
Message par tontonOlive » 19 Mars 2014, 15:56
D'habitude, on démonte les pneus pour récupérer les jantes :)
Moi je voudrai faire l'inverse :lol:
Puis-je démonter des pneus mousse sans les abimer pour les recoller sur d'autres jantes avec la technique des vapeurs d'acétone :?:
Bien entendu, toute autre méthode efficace est bienvenue :)
A bientôt,
Message par rod » 19 Mars 2014, 18:08
Qu'ils soient collés a la cyano ou a la néoprène, l’acétone fonctionne très bien, tu peux y aller.
PeterM
Message par PeterM » 19 Mars 2014, 21:09
Hello,
I have a very effektive methode, but I don´t know how to describe it, but I try:
Search for a point/place, were the rubber is mostly loose. Sting carefuly between the rubber and the rim a long, round thing like a screw-driver (I always use a hudy 2,5mm hex driver, as longer, as better) .
If the tip of the screw driver looks out the other side of the glued tire, begind to turn it carefuly in left and right direction while you hold/fix the side with hex tip with your other hand.
What I mean: Hold the tip and press it in the direction you built up the pressure while you turn the screw-driver left and right.
(You will feel the effect)
In this way you can release all rubbers from the rim AND to 90% you can use the released rubber for any other application!
Hope you understand what I mean... 8O :roll: :? :|
If not, please send me a PM with your @, and I will send you a video!
Salutations, best regards, viele Grüße,
Peter
Message par tontonOlive » 23 Mars 2014, 18:31
Thank you Peter,
I will keep your method for a next time because finally, I didn't buy the wheels.
Thank you again.
Utilisateurs parcourant ce forum : Google Adsense [Bot] et 1 invité
