Championnat italien vintage ?
Message par Tractoricou » 30 Oct 2013, 10:09
Message par Tractoricou » 30 Oct 2013, 10:10
Message par Tractoricou » 30 Oct 2013, 10:11
nodo
Message par nodo » 30 Oct 2013, 14:15
I will try to explain in English, my French is not good at all ...
We are basically thinking to start in 2014 a Championship of Vintage Races.
At this moment in time, we have 3 tracks that have confirmed the project.
One is Fossano, Cuneo nearby the border with South of France. One is in Mantova and the third one will probably be in Tuscany.
The idea is to let all the Classic 2D models pre-2006 run.
There will be an handicap to level all the models on the track, based on:
Year of the model car making and the engine. The more the model is old and up to the original specifications, the lower will the handicap be. The same for the engine, if it is of the same age of the car, the handicap will be 0% and so on for the rest of the car.
Electronic is free to avoid any problem, Gyro and additives are not allowed.
You can see the full Set of Rules on FB at the given address.
Seen that is rather easy and cheap to find cars from the 1995 to the 2006, and we allow modern engines (only with pull start and /or 3 openings (??? I dont know how to say this in english, please help) this could also become an easier way to get (or get back) in our hobby. No pressure, No fierce competition, Relaxed and freindly atmosphere ... something that, at least in Italy, is disappearing also in the Modern Classic 2WD ...
Excusez moi si j'écris peu, mais je ne parle pas français...
Message par Tractoricou » 30 Oct 2013, 18:39
Je vais essayer d'expliquer en anglais, mon français n'est pas bon du tout ...
Nous sommes fondamentalement pensé pour démarrer en 2014 un championnat de courses de cru .
À ce moment-là, nous avons 3 pistes qui ont confirmé le projet.
L'un est Fossano , Cuneo à proximité de la frontière avec le Sud de la France . On est dans Mantoue et la troisième sera probablement en Toscane.
L'idée est de permettre à tous les modèles 2D classique pré -2006 run .
Il y aura un handicap de niveler tous les modèles sur la piste, sur la base de :
Année de la fabrication modèle de la voiture et le moteur. Plus le modèle est vieux et plus aux spécifications d'origine , le plus bas sera le handicap soit. De même pour le moteur , s'il est du même âge de la voiture , le handicap sera de 0% et ainsi de suite pour le reste de la voiture.
Électronique est libre pour éviter tout problème , Gyro et additifs ne sont pas autorisés .
Vous pouvez voir l'intégralité ensemble de règles sur FB à l'adresse indiquée .
Vu que c'est plutôt facile et pas cher de trouver des voitures de la 1995 à la 2006 et nous permettent moteurs modernes ( seulement avec le début de traction et / ou 3 ouvertures ( ? ? Je ne sais pas comment le dire en anglais, s'il vous plaît aider ) cette pourrait également devenir un moyen plus facile d'obtenir (ou revenir ) dans notre hobby. Pas de pression , Pas de concurrence féroce , détendue et sympathique atmosphère ... quelque chose qui , au moins en Italie, disparaît aussi dans les 2 roues motrices classiques modernes ...
Message par garros » 30 Oct 2013, 19:16
deux petites courses de voitures vintages en France la bourguignonne et Beaumont avec de bonnes radio ce serait sympa :ok:
Message par lehornetvosgien » 02 Nov 2013, 20:47
robbe eco,la meilleure des radios :bravo:
PeterM
Message par PeterM » 05 Nov 2013, 13:14
nodo a écrit :I will try to explain in English, my French is not good at all ...
3 Ports
Salutations, best regards, viele Grüße,
Peter
