Some questions on Super J parts
Got a Super J what needs some restoring and completing also don´t have a real manual. Basically it is a mix of CK780 and CK790 with fixed rear axle. Rear wheels are white colour no front wheels. I have seen pictures with white wheels and red wheels with same version as white wheels and other style version with 6 holes.
I think front wheels with the holes might be actually Eagle wheels but sheem working also with Super J. Which wheels should be correct version for CK790, white or red?
Regarding bearings, there are no front bearings also. Which front bearings had been used from factory that time? Metal shielded or plastic shielded, also flanged or non-flanged?
I did read something there had been different bearing size for different style front wheels. Is this true? I found something like 3/16 x 1/2"?
Missing are also some of the locking nuts at front/rear axle and kingpins. Which version is used, regular or low profil locking nuts? I think correct size is 3/8-24 for fixed rear axle and 10-32 for maybe both front axle and king pins? Is this OK?
Thanks for help.
Thanks for help.
MK4, thank you! This is useful information. My car has white rear wheels same style as your left wheel. Have to find matching front wheels or complete set of red wheels. Front bearings should be no problem to find.
I´m looking also for correct locking nuts. I found these are available cheap at hardware shops but doubt they are looking the same as original nuts, maybe too shiny. Do you maybe have picture how original Delta locking nuts for front wheels and for rear wheels (fixed rear axle) would look like? Are these steel or aluminium nuts?
I have checked a lot of pictures but didn´t find one where you clearly see this.
Just found this thread again. Sorry never replied.
Thanks for all the useful informations, it did help when searching for the hardware stuff. I found Delta used a lot of hardware actually intended for aircraft use that time. It´s just bad this stuff is not used today with exactly same look or dimensions.
Front wheel axles and kingpins of the Super-J cars actually "just" are cadmium plated aircraft bolts, also the locknuts are cadmium plated what makes that nice bronze look. I never did like the shiny hardware of today, so I´m happy I found some of the original bolts and locknuts.
These will be used at the CK790E project at other thread also.
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 14 invités
