OCA1
Thank you MK4. It's kind of difficult to differentiate between the CK780 and CK790 and many parts where interchangeable between both versions, so many racers would mix and match the parts. Unfortunately I don't have any documentation on this.MK4 a écrit :super car, delta pan car look cool!!
do you know difference between CK780 and ck790 ?
ck 790 has a straight chassis maybe ? any documents ?
My Delta projects were on hold until now as I was busy with other projects and things. But I will start soon with the Delta cars. One being the original Delta Phaser 1/12 car (at RC10Talk forum) what will be completed now. Also the Spyder has waited very long for being built.OCA1 a écrit :Thank you V12How are your Delta car projects?
This is an early Super J chassis. I have not seen many of these, this is a picture of another car with similar chassis.
Yes, you are correct. this is an HP 20 Gold-Cup car engine. The dimensions and mounting holes are very similar to an OPS 21 side exhaust engine that I plan to install in the future.
