RC500 2WD D&D Graphite
assocista
Message par assocista » 02 Août 2010, 05:35
Hello, Here is the very rare D&D Graphite for RC500 2WD.
The condition is damaged a lot with the scratch and damn holes.
So, I decided to repair it and also re-assemble each parts with refinement.
↓This is a damaged original custom chassis which D&D made circa1983.
↓made the surface smoother with epoxy resin and some chemical treatment.
↓adjusted the colour(German Gray) on the surface like the CFRP production in the early/80's.
↓All the parts are refined and re-assembled. It looks getting nicer.
↓Zoom D&D Graphite. Awesome Shape :D
↓Super Light Weight Spec
Please enjoy ! :wink:
ASSOCISTA :)
OCA1
Message par OCA1 » 02 Août 2010, 06:16
Assocista,
Wow :!: Awesome chassis restoration job :bravo: :bravo: The chassis looks as good as new, very nice job. What type of epoxy resin did you use, is it the same as used for automotive body repair :?:
OCA1 :)
assocista
Message par assocista » 02 Août 2010, 07:43
Hi OCA1, Thank you for your compliment :D
The process is definitely the same way as automotive body.
It's like a skiving and sanding process continuously. should be done one by one carefully.
Regarding the Epoxy resin,It was done by more convenience way in case of this time.
It was epoxy glue which was mixed 2 kind of liquid.This one is quite good for the adhesion with CFRP. The hardness and durability is also enough. :)
ASSOCISTA :fete:
Message par MK4 » 02 Août 2010, 09:18
great lesson of restauration ,for an awesome result !!
do you have paint and varnish the all chassis ? , or only on the rebuilt area ?
Message par mani » 02 Août 2010, 09:20
Haaaaaa, I want the same :bravo: :bravo: :ok:
assocista
Message par assocista » 02 Août 2010, 09:30
MK4/mani, Thanks a lot for your comment.
I did it all the chassis like Top surface and the opposite side of each pieces.
But spray is not too much so that it can be kept the original feeling.
and added a half-transparent spray finally. :wink:
I guess that the important thing is how to make the surface flat completely before spray :D
ASSOCISTA :)
Message par simonsg » 02 Août 2010, 12:25
Bravo :bravo: :bravo: Superb 8)
assocista
Message par assocista » 02 Août 2010, 12:47
Hi Simonsg, Many thanks for your comment :!: :)
How is your project currently? Hope all are smooth 8)
Maybe you are so busy to enjoy the summer vacation :lol:
Cheers!
ASSOCISTA :)
Message par simonsg » 02 Août 2010, 22:12
assocista a écrit :Hi Simonsg, Many thanks for your comment :!: :)
Cheers!
ASSOCISTA :)
Hi ye made a stock of chassis for the winter :lol: at the moment crisis is over and works are plentifull...was just able to pick some parts from a shop in Ryadh SA :lol: :lol: but no Delta spares :( ...also busy running the DXF classic car at the local track :ok:
Your RC500 2WD is really great with such rare optional parts, one of my dreams, the carbon color goes so well with the milky plastic parts :ok:
keep up the good works :ok:
hav fun :fete:
edf84
Message par edf84 » 05 Août 2010, 18:39
Oh elle est vraiment sympa cette caisse...
Je ne savais pas que Associated avait fait une voiture de piste du même type que la PB Nova.
C'est vraiment une belle voiture.
:bravo: :bravo:
assocista
Message par assocista » 05 Août 2010, 23:09
Bonjour edf84 :D many thanks for your comment.
Actually the chassis shape is quite similar to PB Nova.
D&D Graphite has made the other shape one to DELTA Eagle as well. I saw it on the stuff before.
These unitized construction chassis is really light weight and beautiful looking :wink:
Cheers :!:
ASSOCISTA :)
tizgp
Message par tizgp » 06 Août 2010, 18:49
Hello Assocista, i am desperade :( :( because i have one Associated Rc500 NIB but incomplete there are missing some parts, the 3 chassis and front whellhub, do you have?
Traduction automatique:
assocista
Message par assocista » 07 Août 2010, 00:25
Ciao tizgp :) Unfortunately I do not have the stock right now because of having already used it for the previous restoration.
As I have some info, I send a message to you. Pls check it :wink:
Ciao Ciao
ASSOCISTA :D
assoelectro
Message par assoelectro » 13 Août 2010, 10:12
comprends pas mais superbe restauration :ok:
ce caisson me fait pensé a celui de la nova, c'est sortie avant ce kit ?
assocista
Message par assocista » 13 Août 2010, 11:25
Bonjour assoelectro :D Many thanks for your compliment !
D&D released this graphite chassis in the early/'83 as far as I know.
It was a little bit earlier compared with PB Nova '84.
Such kind of chassis must be innovated at that time :wink:
ASSOCISTA :)
